Aug 16th, 2024, 1:06pm
Osc v-ams code (Read 3518 times)
jugemu1234
Osc v-ams code
Mar 09th, 2010, 6:43pm
Can anybody help me debugging following code? When I run this, it ends up DC convergence error around pll_rstb node.
These code might look mess. if there is anyway to make this simpler/better, it would be appreciated.
`include "constants.vams"
`include "disciplines.vams"
`timescale 1ps/1ps
module rosc ( clk, pll_rstb, test_out, dvdd, dvss, en, enExt, extClk, ib_1u, testEn, trim, turbo, turbo_div8, f160M );
input [7:0] trim;
input testEn, enExt, ib_1u, dvdd, dvss, extClk, en, turbo, turbo_div8;
output clk, pll_rstb, test_out, f160M;
logic [7:0] trim;
logic testEn, enExt, en, turbo, turbo_div8;
electrical ib_1u, dvdd, dvss, clk, f160M, test_out, extClk, pll_rstb;
real rin, half_period, freq, adj, jitter, ibias, period, int_clk, int_clk_div8, int_clk_div16, int_clk_div64, int_clk_div512;
integer seed, tgl0, tgl1, tgl2, tgl3, tgl4, tgl5;
analog  begin
   ibias=9*I(dvdd,ib_1u);
   adj=ibias*4;
     if(trim[7])      adj = adj-ibias*2.56;
     if(trim[6])      adj = adj+ibias*1.28;
     if(trim[5])      adj = adj+ibias*0.64;
     if(trim[4])      adj = adj+ibias*0.32;
     if(trim[3])      adj = adj+ibias*0.16;
     if(trim[2])      adj = adj+ibias*0.08;
     if(trim[1])      adj = adj+ibias*0.04;
     if(trim[0])      adj = adj+ibias*0.02;
         //frequency
           freq =  3.5E12*adj+3.4E7;
         half_period= 0.5/freq;
     @(timer(half_period, half_period))
     tgl0=!tgl0;
     int_clk = V(dvdd,dvss) * transition(tgl0, 0.0, 100p, 100p);
     @(timer(half_period*8, half_period*8))
     tgl1=!tgl1;
     int_clk_div8 = V(dvdd,dvss) * transition(tgl1, 0.0, 100p, 100p);
     @(timer(half_period*16, half_period*16))
     tgl2=!tgl2;
     int_clk_div16 = V(dvdd,dvss) * transition(tgl2, 0.0, 100p, 100p);
     @(timer(half_period*64, half_period*64))
     tgl3=!tgl3;
     int_clk_div64 = V(dvdd,dvss) * transition(tgl3, 0.0, 100p, 100p);
     @(timer(half_period*512, half_period*512))
     tgl4=!tgl4;
     int_clk_div512 = V(dvdd,dvss) * transition(tgl4, 0.0, 100p, 100p);
     //$display ("freq is %g", freq ) ;
     //$display ("int_clk is %g", int_clk);
     //$display ("adj is %g", adj);
if(enExt)      begin
     V(clk)<+ V(extClk);
end else begin
     if(!en) begin
           V(f160M)<+0;
           V(clk)<+0;
           V(test_out)<+0;
           V(pll_rstb)<+0;
     end else begin
     if(turbo) begin
           V(f160M)<+int_clk;
           if (turbo_div8)      V(clk)<+int_clk_div8;
           else            V(clk)<+int_clk_div16;
           V(test_out)<+int_clk_div64;
               V(pll_rstb)<+0;
     end else begin
           V(f160M)<+0;
           V(test_out)<+int_clk_div512;
           if(int_clk_div512 > 0.75))      begin
                 V(pll_rstb)<+V(dvdd,dvss);
boe
Re: Osc v-ams code
Reply #1 - Mar 10th, 2010, 6:39am
jugemu1234,
I noticed the following issues (without trying to run it):
	    //frequency
Do you really mean 3.5e12 !???
if(enExt)	begin
	V(clk)<+ V(extClk);
end ...
In this case V(f160M), V(test_out) and V(pll_rstb) are unassigned...
BOE
Re: Osc v-ams code
Reply #2 - Mar 10th, 2010, 7:13am
... and since they're unassigned, they default to open-circuits -- that is, pll_rstb is effectively floating (has no connection to ground through the module).
jugemu1234
Re: Osc v-ams code
Reply #3 - Mar 10th, 2010, 10:48pm
Thanks guys. Simulation runs now.
Btw, New issue came up. I added jitter statement as in following code, but all outputs look not toggling. Displaying intermediate variable "half_period", it seems fine because I can see that randomness was added centered around wanted period. What is the problem with this?
	    //frequency
	    //jitter
	    jt = 1p*$rdist_normal(seed, jt_mean, jt_stdev);
	    //Half period
	    //half_period=(0.5/freq);	//without random jitter
	    half_period=(0.5/freq+jt);	//with random jitter
	    //time offset
	    toffset= 1.5E-6;
	@(timer(half_period+toffset, half_period))
	tgl0=!tgl0;
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Re: Osc v-ams code
Reply #4 - Mar 22nd, 2010, 1:35am
My guess for the output not toggling is that the start time of the timer is dynamic - after the timer has become active the time expression is updated to a value in the past which essentially switches off the timer, even though the period argument would suggest to repeat with given (updated) period. The way around this is to make sure the time expression stays ahead of the current simulation time:
@(initial_step) last_cross = toffset;
@(timer(last_cross + half_period)) begin
  last_cross = $abstime;
  tgl0=!tgl0;
Now the time expression is always into the future.
You can improve accuracy by using the last_crossing operator.
Cheers,
Marq
