Vence,
Attached is an example of how to setup your testbench. This testbench replicates how the circuit will be used, i.e., it includes feedback, etc. The tricky point is that you need perform the dc operating first with the circuit setup for "sampling": sample the short input to reference level and short the common mode input to the common mode reference level, and then run the stability analysis in "gain": apply an input signal and connect the common mode level to the feedback. This is pretty straight forward using ADE-XL [IC61].
