Jul 19th, 2024, 10:23pm
why ac=1(magnitude) while doing ac simulation? (Read 1975 times)
somisetty
Mar 17th, 2010, 9:38pm
would you pls let me know why ac=1(magnitude) while doing ac simulation?
THanks
yvkrishna
Re: why ac=1(magnitude) while doing ac simulation?
Reply #1 - Mar 17th, 2010, 10:08pm
no special reason for it, just a matter of convenience , you can see the gain directly by plotting the output voltage.
regards,
Vamshi
Reply #2 - Mar 18th, 2010, 4:03pm
Essentially if you're doing a linear small signal analysis, it doesn't matter what magnitude the input signal is - the gains will always be the same.
You could choose to put a realistic signal magnitude at the input, and then you'll get a realistic signal at the output, and could then calculate the gain by dividing the output signal by the input signal. By setting the input signal to 1, you directly get the gain (from the input source) at the node you plot.
