Jul 17th, 2024, 10:41am
 MOSFET LEVEL 1&2 verilogA model help! (Read 1178 times)
liletian
MD
Mar 21st, 2010, 11:50am
 Hi Guys
 I am interesting in a simple verilogA mosfet model like level 1or 2. It looks like the level 3 is a little too complicated in the code. Can anyone share their level 1 and 2 verilogA code, I will greatly appreciate it.
 Thank you,
 B
Re:   MOSFET LEVEL 1&2 verilogA model help!
Reply #1 - Mar 22nd, 2010, 8:15am
If you have the Cadence IC tools, then there is a cell "mos_level1" in ahdlLib. ahdlLib can be found at:
<ICinstDir>/tools/dfII/samples/artist/ahdlLib
liletian
MD
Reply #2 - Mar 22nd, 2010, 10:33am
thanks, it looks ok. However, is there a model include the capacitor effect? like level 2 model?
thank you
Andrew Beckett wrote on Mar 22nd, 2010, 8:15am:
Reply #3 - Mar 22nd, 2010, 12:07pm
liletian wrote on Mar 22nd, 2010, 10:33am:
I would have said that level=1 has some capacitance, but it's not in the verilog-a code Andrew mentioned (well, OK, there's diode depletion capacitance, but no channel charge equations).  My sense, though, is that the capacitance equations in levels 1 and 3 are very close, if not the same, and you thought the level 3 equations were too complicated.
liletian
MD
Reply #4 - Mar 22nd, 2010, 12:21pm
 Hi
 It looks like my machine can not compile level 3 correctly. Is there other level 3 mosfet code?
 Bests,
 B
Geoffrey_Coram wrote on Mar 22nd, 2010, 12:07pm:
Reply #5 - Mar 23rd, 2010, 9:59am
liletian wrote on Mar 22nd, 2010, 12:21pm:
 Hi
Did you download the updated mos3 code that Marek posted in your other thread?
http://www.designers-guide.org/Forum/YaBB.pl?num=1268789424#13
Did you use the correct command to include it in your netlist?
Have you tried including the mos level 1 code to be sure you can get Verilog-A code in your netlist?
What error messages are you getting now?
I'm not aware of other mos3 code that's easily available.
