Jul 17th, 2024, 10:37am
Compatibility with Hspice (Read 2638 times)
mohammadfawaz
Mar 22nd, 2010, 2:07pm
Hello all,
I'm new to Verlilog A, and I'm having a problem when trying to compile models that are clock depending such as a counter. How can I use a clock in a model and still be able to use the model in HSPICE?
Thank you
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Re: Compatibility with Hspice
Reply #1 - Mar 23rd, 2010, 2:29am
1. Define an input for the clock signal
inout clk;
electrical clk;
2. Create an event that checks for the clock's edges:
@(cross(V(clk) - thresh, +1)) begin
  count = (count > max_count) ? 0 : count + 1;
  outval = (count == 0);
3. Contribute a value calculated in the event statement to the output
V(out) <+ outval;
Hope this helps,
Marq
mohammadfawaz
Reply #2 - Mar 23rd, 2010, 2:56pm
When I try to compile this using HSPICE, I'm getting an error at "@".
I have HSPICE A-2008.03. Should I have a new version?
Thank you
mohammadfawaz
Reply #3 - Mar 23rd, 2010, 3:09pm
Problem solved. I have a problem with includes..
thanx
