Jul 20th, 2024, 4:25am
ADE doesn't netlist voltage sources (Read 2025 times)
nand_cos
Mar 22nd, 2010, 11:21pm
I am having this weird issue of ADE not netlisting voltage sources. All the components and cells of the technology library are in place, but there are no instance statements for voltage sources.
What could be the issue? Where do I start the debug?
Re: ADE doesn't netlist voltage sources
Reply #1 - Mar 23rd, 2010, 9:55am
I'd start by looking very closely at the log file.
Also check if there are multiple libraries that have voltage source symbols in them; maybe you picked the "wrong" library.
Reply #2 - Mar 27th, 2010, 10:05am
Wonder whether it might be a failure to set "setenv CDS_Netlisting_Mode Analog" before starting icfb/virtuoso. However, that would normally just cause parameters to be missing, not the complete instance.
As Geoffrey said, check for any errors in the CIW.
