Jul 18th, 2024, 9:26am
get spectre assert data from corners (Read 2382 times)
jshafer
Mar 26th, 2010, 10:51am
I'm trying to set some spectre assert checks, which I then want to run over corners using the corners tool. How can I get violation data, if any, from each corner run?
Re: get spectre assert data from corners
Reply #1 - Apr 7th, 2010, 6:23am
Moshtaque
Reply #2 - May 17th, 2010, 5:50pm
Achim,
Any news from cadence on this topic?
> Which version of MMSIM are you using? Device checking seems
> to works by device model in MMSIM62 USR1.
indeed
> The menu includes
> options for subcircuits so they are probably working also.
unfourtunately not (neither subckt nor inline subckt in modelcard)
As soon I get news from Cadence I will post here,
Achim
