Dec 16th, 2025, 2:06am
Verilog-A model for ADC (Read 10263 times)
lyko
Apr 12th, 2010, 2:06am
Dear All
It is posible to get a model of ADC using Verilog(including delay from clk to outputs and an input voltage to 10 or more bits binary numbers.)  Why is Verilog-A usually used in modelling ADC?
I am a beginner in Verilog-A.  :-[
Thanks for your attention.
Lyko
View Profile lyko   IP Logged
Re: Verilog-A model for ADC
Reply #1 - Apr 13th, 2010, 10:51am
lyko wrote on Apr 12th, 2010, 2:06am:
How would you think to represent the Analog input in (digital) Verilog?
Generally, the Analog input signal varies continuously (ramps up or down or something); it's not event-driven like (digital) Verilog.
lyko
Reply #2 - Apr 13th, 2010, 7:42pm
Thanks.  I heard that some IP vendor offered verilog model of ADC for verification.  That's why I asked.
But I would prefer to use verilog-A for modelling based on your reply.
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Reply #3 - Apr 14th, 2010, 1:03am
There are a few simple examples of ADCs in the Verilog-AMS standard. Also, if you have access to the Cadence tooling there are examples in the ahdlLib library delivered with Cadence IC and/or MMSIM.
Cheers,
Marq
