Aug 16th, 2024, 1:11pm
Running average in Verilog-AMS (Read 7739 times)
Cri Azzolini
University of Parma, Italy
Apr 14th, 2010, 7:15am
is there a method to calculate running averages in Verilog-AMS? I would need to measure the running average of a voltage with a time window of TS second. So that the expression in pseudo-math language would be:
avg = 1 /TS * integral_from($asbtime-TS)_to($abstime) vin(x)dx
where $abstime is the running time.
As model output I would need a time continuous function: avg(t).
I am not sure if the VerilogAMS function "idt" is suitable.
Any ideas?
Many thanks,
Cristiano
View Profile WWW cri.azzolini   IP Logged
Re: Running average in Verilog-AMS
Reply #1 - Apr 14th, 2010, 4:40pm
There's an example of doing this on the Cadence Online Support site http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNu...
If that helps...
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Reply #2 - Apr 19th, 2010, 7:54am
In case you are not able to see the answer at the Cadence support site, the answer to your question is: yes, idt is applicable, but you also need to factor in the time window. You can rewrite the integral to the following form:
avg = 1 /TS * integral_from($abstime-TS)_to($abstime) vin(x)dx
avg = 1 /TS * (integral_from(0)_to($abstime) vin(x)dx -
                     integral_from(0)_to($abstime-TS) vin(x)dx)
                     integral_from(TS)_to($abstime) vin(x-TS)dx)
                     integral_from(0)_to($abstime) vin(x-TS)dx)
avg = 1 /TS * integral_from(0)_to($abstime) (vin(x) - vin(x - TS))dx
Now you can use idt() and a delay operator to implement this transformed operation.
Marq
Cri Azzolini
Reply #3 - Apr 20th, 2010, 2:53am
Hi Marq and Andrew,
many thanks for the precious hints.
I'll proceed as suggested!
Bye,
   Cristiano
Cri Azzolini
Reply #4 - Apr 20th, 2010, 4:17am
Hi again,
I just googled this thread with a skill code by Andrew:
http://groups.google.com/group/comp.cad.cadence/browse_thread/thread/bc276d85b43...
I also tried the VerilogAMS code suggested by Marq and they seems quite similar. Actually there is a small discrepancy between the results of the two methods but in my case this may be probably accepted.
Cristiano
