I don't mean to be rude, but do you think anyone is likely to be able to understand what you're asking, based on a low resolution jpeg (I can't even read what the expression names are), with no information at all as to what you've referred to or what you think you're trying to simulate?
Please remember that others cannot see inside your head, and so you need to furnish the reader with as much information as possible in order to elucidate your question and increase the chances of somebody being able to answer.
Maybe somebody can guess what you want - I can't.
And by the way, this would have been better in the Circuit Simulation board rather than Analog Design (Ken will probably move it).
