colorcircle
Hii does someone knows how to use clock in veriloga i need to do the simulation by giving a frequency of 100hz am new to this thing,so would be nice if someone tells
you can take my program as this(example) `include "disciplines.vams" module equation(y,x); output y; input x; voltage x,y; analog begin V(y)<+V(x) end endmodule
i know theres no need for clock in above,,but just explain how i would write syntax,if i need to make simulation for above program with 100Hz clock,,the code for that..(at falling edge of clock)
thank you
