Aug 16th, 2024, 12:59pm
syntax? (Read 1578 times)
colorcircle
syntax?
Apr 23rd, 2010, 12:08pm
Hii
does someone knows how to use clock in veriloga
i need to do the simulation by giving a frequency of 100hz
am new to this thing,so would be nice if someone tells
you can take my program as this(example)
`include "disciplines.vams"
module equation(y,x);
output y;
input x;
voltage x,y;
analog begin
 V(y)<+V(x)
i know theres no need for clock in above,,but just explain how i would write syntax,if i need to make simulation for above program with 100Hz clock,,the code for that..(at falling edge of clock)
thank you
Re: syntax?
Reply #1 - Apr 26th, 2010, 4:41am
Do you want to generate the clock within the module, or have an external clock that comes in through another port?
Did you look through the Functional Models on the Verilog-AMS page (click "Verilog-AMS" in the header bar of this web site, between Forum and Analysis)?
