Aug 15th, 2024, 3:03am
Pages: 1 2 3
MLIN simulation question in RFDE (Read 34263 times)
liletian
MD
Apr 27th, 2010, 8:51am
 Hi Guys
 I am simulating a filter using transmission line. I use MLIN for the transmission line in ADS. The software reports the following errors.
Can anyone suggest how to fix it? It seems to complain I did not give the model for substrate which I specified as Msub1. Do I need to give a seperate substrate file? If so, can anyone give me a sample Msub1 file.
 I will greatly appreciate it.
 hpeesofsim (*) 350.500 Feb 18 2009 (built: 02/18/09 23:50:00)
Copyright Agilent Technologies, 1989-2008.
Warning detected by hpeesofsim during netlist flattening.
   Cannot find substrate `MSub1'.
Error detected by hpeesofsim during netlist flattening.
   `I4':  Expected a substrate model for parameter `Subst'.
Flushing data (please wait) ...
Re: MLIN simulation question in RFDE
Reply #1 - Apr 27th, 2010, 9:29am
I can't find out any design issue in your post.
Your questions are no more than very easy issues regarding usage of very specific vendor's tool.
liletian wrote on Apr 27th, 2010, 8:51am:
See http://www.designers-guide.org/Forum/YaBB.pl?num=1265012932
http://edocs.soco.agilent.com/display/ads2009/MSUB+%28Microstrip+Substrate%29
This is also available in "adsLib" of Agilent RFDE.
liletian
MD
Reply #2 - Apr 27th, 2010, 10:10am
 Hi pancho
 Thanks for your comments, I did find there is a component in adsLib called MSUB. However, can you specify how I can solve the problem? Any suggestions? Most of the adsLib components work fine so far except Mlin.
 I put a MSUB into the schematics and it still reported the same error.
 Thank you
pancho_hideboo wrote on Apr 27th, 2010, 9:29am:
Reply #3 - Apr 27th, 2010, 10:13am
Show me schematic and netlist.
I think you will fail in creating netlist because I think there are many mistakes in your schematics.
liletian
MD
Reply #4 - Apr 27th, 2010, 10:15am
 I attached the schematics, I did not find netlist file in the directory.
Reply #5 - Apr 27th, 2010, 10:17am
No. this is not substrate definition component.
liletian wrote on Apr 27th, 2010, 10:15am:
Do you understand simulation launch mechanithm in RFDE ?
See http://www.designers-guide.org/Forum/YaBB.pl?num=1265391679
liletian
MD
Reply #6 - Apr 27th, 2010, 10:19am
could you please tell me how to define it?
thanks
pancho_hideboo wrote on Apr 27th, 2010, 10:17am:
Reply #7 - Apr 27th, 2010, 10:23am
Show me netlist.
liletian wrote on Apr 27th, 2010, 10:19am:
Simply place substrate definition component in schematic.
In your schematic, there is no one.
liletian
MD
Reply #8 - Apr 27th, 2010, 10:28am
pancho_hideboo wrote on Apr 27th, 2010, 10:23am:
Show me netlist.
I am sorry, it might be dummy question. But can you tell me how to place substrate definition component in schematic? The closest component I found in adsLib is MSUB. Please give details, thank you so much!
Reply #9 - Apr 27th, 2010, 10:31am
In your schematic, there is no "adsLib/MSUB".
There are "MLIN", "TLIN", "Term", "analogLib/cap", "analogLib/res" and "analogLib/gnd".
Again see http://www.designers-guide.org/Forum/YaBB.pl?num=1265012932
From your all previous posts, I think you can't understand ADS and RFDE at all.
liletian
MD
Reply #10 - Apr 27th, 2010, 10:36am
yes, I mixed the components from analogLib and adsLib. Thank you for your reply. I will have a look on the post.
Why do you think I do not understand RFDE at all.
I think RFDE is a software to use ADS simulator and library. And at the same, use cadence to layout.
 Are there more deep understanding on RFDE?
 Thank you again
pancho_hideboo wrote on Apr 27th, 2010, 10:31am:
Reply #11 - Apr 27th, 2010, 10:38am
liletian wrote on Apr 27th, 2010, 10:36am:
Mixture of "analogLib" and "adsLib" is no problem.
See all your previous posts in both "this forum" and "http://www.edaboard.com/forum63.html".
liletian
MD
Reply #12 - Apr 27th, 2010, 10:44am
It is might be true I did not know ADS too much.
I modified the schematics, now it reported new errors.
Here is the error.
Any suggestions?
Error detected by hpeesofsim during netlist parsing.
   ADS-syntax parser error in `input.ckt', line 6:
       syntax error
hpeesofsim terminated due to an error.
ds2psf_exe--ERROR: Cannot access file /home/hehe/simulation/test_TL_filter/ADSsim/schematic/netlist/data.ds.
\nds2psf was unsuccessful.  PSF files are not available for this simulation.
pancho_hideboo wrote on Apr 27th, 2010, 10:38am:
See all your previous posts.
Reply #13 - Apr 27th, 2010, 10:48am
There is a substrate definition component in this schematic(http://www.designers-guide.org/Forum/Attachments/Screenshot-3_001.png).
liletian wrote on Apr 27th, 2010, 10:44am:
       syntax error
Show me netlist.
liletian
MD
Reply #14 - Apr 27th, 2010, 10:52am
pancho_hideboo wrote on Apr 27th, 2010, 10:48am:
There is a substrate definition component in this schematic.
Did you understand there is no one in previous your schemtic ?
       syntax error
Show me netlist.
 Now I understood there was no substrate in my previous post. I did not realize I need to put it in the schematics. First time to have this question.
thank you!
I did not find netlist file in my directory. I attached the totally directory file.
thank you
Pages: 1 2 3
