Jul 16th, 2024, 11:37am
Pages: 1 2 3
MLIN simulation question in RFDE (Read 34038 times)
liletian
MD
Re: MLIN simulation question in RFDE
Reply #15 - Apr 27th, 2010, 11:00am
pancho_hideboo wrote on Apr 27th, 2010, 10:58am:
Later I will do netlisting of your schematic("test_TL_filter_tar.gz").
thank you, I am looking forward to your reply.
Grin
liletian
MD
Reply #16 - Apr 28th, 2010, 7:40am
liletian wrote on Apr 27th, 2010, 11:00am:
Grin
 hi pancho
 Did you have a look on the file? What is the problem?
 Thank you,
 B
Reply #17 - Apr 28th, 2010, 8:16am
liletian wrote on Apr 27th, 2010, 10:44am:
Error detected by hpeesofsim during netlist parsing.
   ADS-syntax parser error in `input.ckt', line 6:
       syntax error
(1) Don't enclose MSub1 for "Subst" parameters of "MLIN" with double quotations if you use RFDE(ADSsim).
This is a syntax error in the above.
See schematic for ADSsim in attached figure.
On the other hand, you can enclose with double quotations if you use Agilent GoldenGate.
(2) Callback skill code for netlisting of "adsLib/MSUB" is corrupted due to some reason.
My RFDE is CDBA version of RFDE2008Update2.
As far as CDBA version of RFDE2008Update2, callback skill code for netlisting of "MSUB" can't work.
Try to use OpenAccess version, for exaple, OpenAccess version of RFDE2009 which is a final version of RFDE.
(3) As workaround, don't place "adsLib/MSUB" in schematic.
Instead include netlist scratch for "MSUB".
It is easily available in ADS native environment.
(4) Use Agilent GoldenGate instead of Agilent RFDE.
Reply #18 - Apr 28th, 2010, 8:29am
The followings are netlist sets for RFDE(ADSsim).
"test_TL_filter.ads" Quote:
simulator lang=ads
Options ResourceUsage=yes Verbose=yes UseNutmegFormat=no TopDesignName="data"
; Generated by: DFII version 5.10.41.500.5.98 (using OASIS direct)
#include "~/RFDE/msub1.ads"
MLIN2:I4 net06 net7 Subst="MSub1" W=250.00u L=5m Wall1=1e+30 Wall2=1e+30 Mod=1
simulator lang=spectre
PORT1 (net06 0) port r=50 num=1 type=dc
PORT2 (net7 0) port r=10M num=2 type=dc
C0 (net7 0) capacitor c=100.0f
simulator lang=ads
Options:Options1 Temp=25.0 Tnom=27 TopologyCheck=yes GiveAllWarnings=yes MaxWarnings=10
S_Param:SP1 SweepVar="freq" SweepPlan="SP1_stim" CalcS=yes StatusLevel=2 \
   CalcNoise=no OutputPlan[1]="GlobalOutputPlan" OutputPlan[2]="GlobalInhibitPlan"
SweepPlan:SP1_stim Sort=yes Start=1k Stop=10G Dec=21
OutputPlan:GlobalOutputPlan Type="Output" UseBuiltinRule=no \
   OverrideInhibitRule=no UseNodeNestLevel=yes NodeNestLevel=2 \
   UseCurrentNestLevel=yes CurrentNestLevel=999 \
   UseDeviceCurrentNestLevel=no
OutputPlan:GlobalInhibitPlan Type="Inhibit" UseBuiltinRule=no \
   OverrideInhibitRule=no NodeRegExpr[1]="\.net[0-9]+$|^net[0-9]+$"
mapping {
 pinMapping {
   capacitor 1:"PLUS" 2:"MINUS"
   port 1:"PLUS" 2:"MINUS"
   MLIN2 1:"P1" 2:"P2"
"msub1.ads" Quote:
simulator lang=ads
model MSub1 MSUB H=10.0u Er=9.6 Mur=1 Cond=1e+50 Hu=1e+36 T=0 TanD=0 Rough=0
Reply #19 - Apr 28th, 2010, 8:36am
The following is a netlist for Agilent GoldenGate.
"test_TL_filter_GG.scs" Quote:
// Generated for: spectre
// Generated on: Apr 28 15:40:05 2010
// Design library name: My_RFDE_Test
// Design cell name: test_TL_filter_GG
global 0
// Library name: My_RFDE_Test
// Cell name: test_TL_filter_GG
// View name: schematic
I4 (net06 net7) MLIN Subst="MSub1" W=250.00u L=5m Wall1=1e+30 Wall2=1e+30 Mod=Kirschning
liletian
MD
Reply #20 - Apr 28th, 2010, 8:53am
How to do the netlist? It looks like RFDE does not generate the netlist for me.
(4) Use Agilent GoldenGate.
I rarely use GoldenGate and just give it a try. It reported the same errors.
pancho_hideboo wrote on Apr 28th, 2010, 8:29am:
simulator lang=ads
simulator lang=ads
mapping {
 pinMapping {
   MLIN2 1:"P1" 2:"P2"
"msub1.ads" Quote:
simulator lang=ads
Reply #21 - Apr 28th, 2010, 8:55am
liletian wrote on Apr 28th, 2010, 8:53am:
Use "adsLib" for GoldenGate not for RFDE.
It is same as Cadence spectre's netlisting in Cadence ADE.
Do you understand Cadence ADE ?
About netlisting in ADS native environment, see http://www.designers-guide.org/Forum/YaBB.pl?num=1265191125/7#7
liletian
MD
Reply #22 - Apr 28th, 2010, 8:59am
how to use this file?
can you please give me the totally directory of the RFDE ADS, so I can have a look?
thanks
simulator lang=ads
simulator lang=ads
mapping {
 pinMapping {
   MLIN2 1:"P1" 2:"P2"
"msub1.ads" Quote:
simulator lang=ads
Reply #23 - Apr 28th, 2010, 9:00am
Read all documenations of Agilent RFDE and Cadence ADE.
liletian wrote on Apr 28th, 2010, 8:59am:
Include "msub1.ads" just same as transistor model file.
Again do you understand Cadence ADE ?
liletian
MD
Reply #24 - Apr 28th, 2010, 9:01am
My understanding is Goldsden gate is only a simulator under RFDE. Again, I do not know much on Golden Gate.
pancho_hideboo wrote on Apr 28th, 2010, 8:55am:
liletian
MD
Reply #25 - Apr 28th, 2010, 9:03am
 no, I do not know how to do it. can you tell me how to use it?
Reply #26 - Apr 28th, 2010, 9:03am
liletian wrote on Apr 28th, 2010, 9:01am:
Not correct.
http://www.designers-guide.org/Forum/YaBB.pl?num=1268404959/7#7
I'm not kind and patient enough for answering such too basic questions.
liletian
MD
Reply #27 - Apr 28th, 2010, 9:18am
pancho_hideboo wrote on Apr 28th, 2010, 9:03am:
Not correct.
It is fine. I do not really need to know what golden Gate is?
If you can tell me how to use the netlist you showed to me in ADS, I will greatly appreciate your help.
Otherwise, thank you anyway for your help.
Reply #28 - Apr 28th, 2010, 9:23am
liletian wrote on Apr 28th, 2010, 9:18am:
I don't think you can manage to use Agilent GoldenGate, if I judge from all your previous posts in both "this forum" and "http://www.edaboard.com/forum63.html".
Again see http://www.designers-guide.org/Forum/YaBB.pl?num=1272383469/23#23.
Simply include "msub1.ads" just same as transistor model file including when you use Spectre in Cadence ADE.
liletian
MD
Reply #29 - Apr 28th, 2010, 9:49am
pancho_hideboo wrote on Apr 28th, 2010, 9:23am:
whatever you say, thank you for your help. I finally got it to work.
Thanks a lot!
Pages: 1 2 3
