liletian wrote on Apr 27th, 2010, 10:44am:Error detected by hpeesofsim during netlist parsing.
ADS-syntax parser error in `input.ckt', line 6:
syntax error
(1) Don't enclose MSub1 for "Subst" parameters of "MLIN" with double quotations if you use RFDE(ADSsim).
This is a syntax error in the above.
See schematic for ADSsim in attached figure.
On the other hand, you can enclose with double quotations if you use Agilent GoldenGate.
(2) Callback skill code for netlisting of "adsLib/MSUB" is corrupted due to some reason.
My RFDE is CDBA version of RFDE2008Update2.
As far as CDBA version of RFDE2008Update2, callback skill code for netlisting of "MSUB" can't work.
Try to use OpenAccess version, for exaple, OpenAccess version of RFDE2009 which is a final version of RFDE.
(3) As workaround, don't place "adsLib/MSUB" in schematic.
Instead include netlist scratch for "MSUB".
It is easily available in ADS native environment.
(4) Use Agilent GoldenGate instead of Agilent RFDE.
