Marq Kole
Hmmm. That's weird...
Eindhoven, The Netherlands
If you open the results browser from the calculator and go to the variable you want to use (assuming you have saved it to the PSF with the saveahdlvars option in Spectre) you can right-click the mouse button when you have selected it. This will bring up a drop-down menu where the bottom item is "calculator". Clicking on this will make the variable available in the calculator. You get an entry starting with "getData" - I'm not sure this is easily to reproduce in an OCEAN script but it will get you the data you need in the calculator.
Cheers, Marq
