Jul 18th, 2024, 10:05pm
number of digits in ADE results display (Read 6616 times)
subgold
May 26th, 2010, 1:55am
when using ADE and its results display window, there are always by default four digits shown for all the result values. are there any ways to change it to more digits? or which parameters in the environment/initial setup files are related? and it would be better if i could define the location of the decimal point/number of significant figures.
i am using cadense 5.10.41. thx in advance for your answers.
Re: number of digits in ADE results display
Reply #1 - May 26th, 2010, 3:33pm
If the results are produced by Spectre, you could set the number of digits you want using the 'digits' option.
subgold
Reply #2 - May 27th, 2010, 5:02am
hi ken,
thx for ur answer.
i am using spectre, do you mean Simulation->Options->Analog...->digits?
the default value is 5 and i changed it to 8, nothing happened, still got the same number of digits as before.
how exactly should i change the option?
Reply #3 - May 27th, 2010, 8:31am
Subgold,
Woooooooooh, ic 5.10.41...
After you display the results in a table, the default value is 4 digits.
  • Click the column(s) that you want to change the number of digits.
  • Click the right button of the mouse, select Format.... A window named Format Attributes pops up.
  • Change the number in Significant digits.
  • Click OK or Apply. The job is done.
Yawei
ghatcher
Reply #4 - Jul 20th, 2010, 11:10am
If you want to see a different number of significant digits displayed in the schematic, you can use this command.
aelPushSignifDigits(x)
Where x is the number of digits you want displayed.  This is useful for looking at the DC voltage and operating points in the schematic without having the print the operating points.
Hope this helps! Smiley
sudhar_v
Reply #5 - Jul 23rd, 2010, 8:51am
@ghatcher
Great tip! many thanks!
