Sep 22nd, 2026, 7:48pm
Alexander PFD (Read 9012 times)
neoflash
Mixed-Signal
Designer
Alexander PFD
May 26th, 2010, 10:59am
Almost all BB-PD used in CDR have no frequency detection capability.
What kind of behavior they will show if there is large frequency offset between data and local sampling clock?
Neo
love_analog
Re: Alexander PFD
Reply #1 - May 31st, 2010, 6:56am
They will a parallel Frequency detector loop. Once the VCO is brought within range, you will switch over to the PD loop
loveanalog.blogspot.com
The Power of Analog
supermoment
Re: Alexander PFD
Reply #2 - Jun 2nd, 2010, 8:49pm
typically BB-PD has a narrow LPF bandwidth compared to linear PD
supermoment
Re: Alexander PFD
Reply #3 - Jun 11th, 2010, 4:37am
Only feedforward CDR architecture (aka oversampling type) does not have frequency detector.
KangSub
Re: Alexander PFD
Reply #4 - Jul 24th, 2010, 12:32am
hi,
followings are my opinion.
If there are large frequency offset between clock and data, BBPD will produce the random sequence of UP and DN outputs.
BBPD uses at least 3-sample in consecutive 2-UI for phase detection between clock and data and produces valid UP and DN according to the position of data transition.
on the other words, BBPD detects the position of data transition relative to that of clock, using consecutive 3-samples in 2-UI.
so, the frequency of clock and data have to be equal.
if there exist large frequency offset between data and clock, then, BBPD cannot sample 3-sample in consecutive 2-UI and cannot operate properly.
in that case, the 3-samples have no information about the position of the data transition.
therefore, the output of the BBPD is not meaningful.
if the input data is PRBS, because the probability that sampled bit is 0 or 1 is always same, the UP and DN output of BBPD will also random sequence.
I don't think that Alexander BBPD  can detect any frequency information.
thanks,
- KangSub
Re: Alexander PFD
Reply #5 - Aug 31st, 2010, 3:39pm
Um... this is covered in a dozen textbooks...
look into pull in range, and frequency acquisition vs phase acquisition.
neoflash
Mixed-Signal
Designer
Re: Alexander PFD
Reply #6 - Aug 31st, 2010, 4:31pm
Thanks for bring this reference source up.
Would you like to list 1-2 text books which you think are best in describing this issue?
Thanks.
loose-electron wrote on Aug 31st, 2010, 3:39pm:
