Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Apr 25
th
, 2024, 10:56pm
Home
Help
Search
Login
Register
PM to admin
Design
High-Speed I/O Design
› USB 2.0 Low Speed Buffer Up/Down Stream Difference
Previous topic
Next topic
USB 2.0 Low Speed Buffer Up/Down Stream Difference (Read 3621 times)
neoflash
Mixed-Signal
Designer
Jun 03
rd
, 2010, 5:10pm
Why in USB 2.0 spec, the drive loading capability is different between up and down steam facing ports?
For downstream, it is 200-600pF while for upstream it is 50-150pF?
IP Logged
supermoment
Re: USB 2.0 Low Speed Buffer Up/Down Stream Difference
Reply #1 -
Jun 11
th
, 2010, 6:14am
It gives more stringent rules to downstream ports (host & HUB) since they have power supply.
While upstream ports normally is a device which get power from host or HUB. So their driving capability is less.
Hopefully it is correct.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
»» High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
