Jul 17th, 2024, 12:39pm
unable to display verilogA waveform (Read 4063 times)
supermoment
Jun 14th, 2010, 8:30pm
when I simulate verilogA xor gate (copied from desinger-guide.org), Cadence CIW shows that "wave3 is not a waveform object tat can be displayed and will be turned OFF automatically"
There is no error on the code and I could simulate other verilogA code like latch.
xor verilogA code:
`include "constants.vams"
`include "disciplines.vams"
module axor (out, in1, in2);
//Copied from designers-guide.org
	  output out; voltage out;
	  input in1, in2; voltage in1, in2;
	  parameter real vh = 1;			// output voltage in high state
	  parameter real vl = 0;			// output voltage in low state
	  parameter real vth = (vh + vl)/2;	 // threshold voltage at inputs
	  parameter real td = 0 from [0:inf);     // delay to start of output transition
	  parameter real tt = 0 from [0:inf);     // transition time of output signals
	  analog begin
		    @(cross(V(in1) - vth) or cross(V(in2) - vth))
		    V(out) <+ transition( ((V(in1) > vth) ^ (V(in2) > vth)) ? vh : vl, td, tt );
May I know why? I am new to verilogA.
I am using cadence 5141, mmsim61 spectreRF
Re: unable to display verilogA waveform
Reply #1 - Jun 15th, 2010, 4:47am
I don't see "wave3" in the Verilog-A code.  Perhaps you have a typo in your netlist?
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Reply #2 - Jun 15th, 2010, 2:51pm
Indeed, as Geoffrey suggests the test bench for this Verilog-A model will give more information about the origins of the error message. The xor gate model is fine and would not give rise to the kind of error you indicated.
Marq
supermoment
Reply #3 - Jun 15th, 2010, 10:02pm
thx for your reply.
it works after restarting the icfb..
but dont know why..
wave3 is the out of the xor in the test bench.
