unevb
Simulator : Cadence Spectre Using Monte Carlo tool in the Virtuoso Analog Design Environment
I am trying to find the offset voltage of an analog comparator by keeping one input (INM) at common mode voltage and applying a ramp to the other input (INP). Using monte carlo tool to do multiple iterations
I run a transient simulation
I first measure the time at while the output (compout) crosses Vdd/2 (0.6) Tcross = cross(VT("/compout") 0.6 1 "rising" nil nil)
finally I would like the use value at INP at Tcross to find the threshold point of the circuit using
IN_thresh = value(VT("/vinp") Tcross)
But this does not work because it appears the outputs are not evaluated sequentially! and the value of Tcross is not available when the tool tries to compute IN_thresh. Any work around for this?
