Jul 19th, 2024, 9:16am
time resolution in printed output with strobeperiod; problem with FFT (Read 17383 times)
nrk1
Jun 30th, 2010, 10:35pm
I have encountered a problem with the time resolution of the printed data with 5.10.41_USR6.127.29.
I simulate a circuit with only a sinewave source (10MHz) for 1us with strobeperiod of 1u/512(=1.953125e-09) and take the DFT with the same time points(0 to 1u with 512 points). There are weird components at 14MHz, 34MHz etc. I traced this down to what data comes out when I use, say ocnPrint. The first six points are given below:
ocnPrint(?output "test.dat" ?numberNotation 'none VT("/in"))
0                 0
1e-09             0.122411
3e-09             0.24298
5e-09             0.359895
7e-09             0.471397
9e-09             0.575808
The x values are rounded to 1ns, but the y values correspond to 0, 1u/512, 2u/512 etc.! When I export the data to matlab and take a DFT of the second column, it is clean, as expected.
When I specify the step size in ocnPrint, the output is [using ocnPrint(?output "test.dat" ?from 0 ?to 1u ?step 1u/512 ?numberNotation 'none VT("/in")) ]
0                 0
1.953125e-09      0.17986958
3.90625e-09       0.295957224
5.859375e-09      0.407805923
7.8125e-09        0.51381389
9.765625e-09      0.612462781
Now the t values are right, but the y values are interpolated from the table before. When I take DFT in wavescan's calculator, it takes the DFT of these points and throws up horrible harmonics. So I am unable to find distortion correctly with strobing(whose main point is to be able to calculate distortion without interpolated points)
This is not affected by specifying number of digits in analog options, or precision in ocnPrint. It is also not affected by specifying the strobeperiod as 1u/512 or 1.953125e-09 or 1.953125n. This problem wasn't there in IC5141_ISR500.2.29 but I'd seen it in an even earlier version. The bottomline seems to be that the simulation is fine, the problem is with the way data is output and passed on to the calculator.
Hoping for a solution
Cheers
Nagendra
Re: time resolution in printed output with strobeperiod; problem with FFT
Reply #1 - Jul 1st, 2010, 5:49am
I did a search on "digits" in the Circuit Simulator board over the last year and found many similar topics.  Perhaps:
http://www.designers-guide.org/Forum/YaBB.pl?num=1266336043/3#3
nrk1
Reply #2 - Jul 1st, 2010, 7:18am
It didn't work. Also, the problem is not just with CIW display from ocnPrint. When I take the DFT in calculator, it uses the strange x values to interpolate. Additionally, the rounding is only when strobeperiod is set. Without strobing, I get the following, again correct values, but not good enough to detect low level distortion because of interpolation in uniformly spaced DFT.
Nagendra
output of ocnPrint without strobing
0                 0
1e-09             0.00628314
1.25e-09          0.0078539
1.75e-09          0.0109954
2.75e-09          0.0172779
4.75e-09          0.0298407
8.75e-09          0.0549502
1.55148e-08       0.0973281
2.34131e-08       0.146579
nrk1
Reply #3 - Jul 1st, 2010, 9:37am
Sorry didn't include simulator/version in the original post
ic: sub-version 5.10.41_USR6.127.29 (32-bit addresses)
simulator: spectre (ver. 5.10.41_USR6.081308 -- 13 Aug 2008).
Below are the results from the commands you mentioned. Same truncation occurs. (Again, not altered by printf with more digits etc.)
I've also attached a plot with the sine plotted near its 0deg. and 180deg. Red is with strobing, and green without.
Nagendra
x_vec = drGetWaveformXVec( VT("/in") )
y_vec = drGetWaveformYVec( VT("/in") )
drGetElem(x_vec, 0)
0.0
drGetElem(x_vec, 1)
1e-09
drGetElem(x_vec, 2)
3e-09
drGetElem(x_vec, 3)
5e-09
drGetElem(x_vec, 4)
7e-09
drGetElem(x_vec, 5)
9e-09
drGetElem(x_vec, 6)
1.1e-08
drGetElem(y_vec, 0)
0.0
drGetElem(y_vec, 1)
0.01227154
drGetElem(y_vec, 2)
0.02454123
drGetElem(y_vec, 3)
0.03680722
drGetElem(y_vec, 4)
0.04906767
drGetElem(y_vec, 5)
0.06132074
drGetElem(y_vec, 6)
0.07356456
nrk1
Reply #4 - Jul 1st, 2010, 9:47am
Just realized that I may have confused the issue with inconsistent numbers. The numbers in the first post were with a 10MHz sinewave. I was folling around with it and in the next two, the numbers and the plot are with a 1MHz sinewave. The results from ocnPrint and drGetElem match in either case. Below is drGetElem for 10MHz wave, consistent with the first post.
drGetElem(y_vec, 0)
0.0
drGetElem(y_vec, 1)
0.1224107
drGetElem(y_vec, 2)
0.2429802
drGetElem(y_vec, 3)
0.359895
drGetElem(y_vec, 4)
0.4713967
drGetElem(y_vec, 5)
0.5758082
drGetElem(y_vec, 6)
0.671559
nrk1
Reply #5 - Jul 1st, 2010, 9:59am
psf attached. spectre/1 is without strobing, spectre/2 is with strobing (1u/512). The directories have the netlists as well.
Thanxalot
Nagendra
Reply #6 - Jul 2nd, 2010, 4:51am
Your problem is a bug of Cadence Spectre Version-5.X.X.
Output data format is "sst2", if you run Spectre from Cadence ADE.
See head of "2/psf/spectre.out". The followings are extractions from it.
Quote:
Command line:
   /cad/tools/cadence/tools.lnx86/spectre/bin/32bit/spectre -env  \
       artist5.1.0 +escchars +log ../psf/spectre.out +inter=mpsc  \
       +mpssession=spectre0_15424_8 -format sst2 -raw ../psf  \
       +lqtimeout 900 input.scs
spectre pid = 16764
If you change output data format to "psfbin", problem can be resolved even if you use Cadence Spectre Version-5.X.X.
If you want to change output data format to "psfbin", set like following in Cadence ADE.
     ADE > setup > Environment
     Enter "-format psfbin" in "userCmdLineOption". Here you must not enter '"'.
I checked following versions of Cadence Spectre.
@(#)$CDS: spectre  version 5.1.0 09/19/2007 10:08 (intelibm18.Cadence.COM) $
@(#)$CDS: spectre  version 6.2.0 09/19/2007 13:58 (usimlx112) $
@(#)$CDS: spectre  version 7.1.0 32bit 04/21/2009 11:50 (sjfdl189) $
This problem occurs only in Spectre 5.1.0.
This bug is fixed in both Spectre 6.2.0 and 7.1.0.
So if you use newer Spectre, you don't have to change data format at all.
« Last Edit: Jul 2nd, 2010, 10:57pm by pancho_hideboo »
nrk1
Reply #7 - Jul 2nd, 2010, 7:15am
Ah, it works.
Cool. Thanks again
Nagendra
