Aug 16th, 2024, 4:12pm
Module instantiation using Generate in Verilog-A (Read 259 times)
kumar.g
Frankfurt, Germany
Jul 02nd, 2010, 1:50am
I am using a generate statement to instantiate a delay module (cur_starved_delay) 11 times. The basic idea is to model a 11 stage ring oscillator using current starved delay cell. But i get syntax error in generate statement. Can anyone help me with this. The code is attached below.
`include "constants.vams"
`include "disciplines.vams"
module cur_starved_delay (Vin,Vbias_p,Vbias_n,Vdd,Vss, Vout);
parameter real C_load = 1e-12;
parameter real Kp = 1;
parameter real Kn = 1;
parameter real Vt = 0.2;
parameter real pos_tol = 0.2;
parameter real neg_tol = -0.2;
input Vin,Vbias_p,Vbias_n,Vdd,Vss;
output Vout;
voltage Vin,Vbias_p,Vbias_n,Vdd,Vss,Vout;
voltage V_swing,Vsg_p,Vgs_n;
current I_p,I_n;
real Td_p,Td_n,V_ph;
analog begin
V(V_swing) <+ V(Vdd) - V(Vss);
V(Vsg_p) <+ V(Vdd) - V(Vbias_p);
V(Vgs_n) <+ V(Vbias_n) - V(Vss);
I(I_p) <+ Kp*pow((V(Vsg_p) - Vt),2);
I(I_n) <+ Kn*pow((V(Vgs_n) - Vt),2);
if ((V(Vin) <= V(Vss) + pos_tol) && (V(Vin) >= V(Vss) - neg_tol)) begin
Td_p = (V(V_swing)/I(I_p))*C_load;
else if ((V(Vin) <= V(Vdd) + pos_tol) && (V(Vin) >= V(Vdd) + neg_tol))
Td_n = (V(V_swing)/I(I_p))*C_load;
@(cross(V(Vin)-(V(V_swing)/2),+1)) begin
V_ph = V(Vss);
@(cross(V(Vin)-(V(V_swing)/2),-1)) begin
V_ph = V(Vdd);
V(Vout) <+ transition(V_ph,0,Td_p,Td_n);
module multiphase_vco(Vbias_p,Vbias_n,Vdd,Vss, out);
parameter integer ZERO_BIT = 0;
parameter integer NO_STAGE = 11 from [3:67];
genvar i;
input Vbias_p,Vbias_n,Vdd,Vss;
output [NO_STAGE-1:0] out;
voltage Vbias_p,Vbias_n,Vdd,Vss;
electrical [NO_STAGE-1:0] out;
electrical [NO_STAGE:0]ph_out;
generate
for (i =1;i<=11;i=i+1) begin
cur_starved_delay #(.C_load(C_load),.Kp(Kp),.Kn(Kn),.Vt(Vt),.pos_tol(pos_tol),.neg_tol(neg_tol))
D_i(.Vin(ph_out[i-1]),.Vbias_p(Vbias_p),.Vbias_n(Vbias_n),.Vdd(Vdd),.Vss(Vss),.Vout(ph_out[i]));
endgenerate
analog begin
V(ph_out[0]) <+ V(ph_out[NO_STAGE]);
@(initial_step) begin
V(ph_out[ZERO_BIT]) <+ V(Vss);
View Profile kumar.g write2rammy   IP Logged
kumar.g
Frankfurt, Germany
Re: Module instantiation using Generate in Verilog-A
Reply #1 - Jul 2nd, 2010, 5:59am
I referred to Verilog-AMS ref Manual Ver. 2.3.1(Pg 139). I even tried comenting generate and endgenerate statements but still it gave me error in for loop. In Verilog-A ref manual there is no detail for module instantiation using generate. They have given few examples only for some expression statements but not module instantiation
Reply #2 - Jul 2nd, 2010, 6:07am
kumar.g wrote on Jul 2nd, 2010, 1:50am:
genvar i;
generate
endgenerate
What is "D_i" ?
Try to write "D[i]" or "D<i>", although I don't confirm them.
kumar.g
Frankfurt, Germany
Reply #3 - Jul 2nd, 2010, 8:17am
D_i is just component name. It doesn't get changed. The simulator will assign D_i.Inst[i] as each components name. So I guess we can't change D[i] or D<i>.
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Reply #4 - Jul 5th, 2010, 2:37am
There is nothing wrong with the name D_i. You cannot even use D[i] or D<i> according to the standard - the array reference is provided in the scope of the generate block.
Are you certain that the loop generate statements are supported by your simulator? To my knowledge - which may be outdated - no commercial Verilog-A compiler currently supports the generate constructs.
Cheers,
Marq
kumar.g
Frankfurt, Germany
Reply #5 - Jul 5th, 2010, 6:38am
I am not sure with that. But I use Cadence ICFB 5.14
Marq Kole
Hmmm. That's
weird...
Reply #6 - Jul 5th, 2010, 7:53am
With that version of Cadence IC - assuming you use the spectre versino that is part of that release - you will not get any support for features newer than Verilog-AMS 2.1 annex C. Although I would first suggest to start using Cadence MMSIM, you will also not see any support for the generate statements in the latest versions of Spectre. However Cadence MMSIM (which includes Spectre) will have the rest of the Verilog-A support more up to date and generally faster.
I'm afriad you will have to rework your model without the generate statement.
Cheers,
Marq
kumar.g
Frankfurt, Germany
Reply #7 - Jul 6th, 2010, 12:14am
Thank you very much for the clarification
