Jul 17th, 2024, 12:49pm
Issues in Modelling an INV output having 10mVp-p as its VSS (Read 2144 times)
kumar.g
Frankfurt, Germany
Jul 05th, 2010, 2:28am
Hallo All,
       I am designing a current starved INV which has an output high(VDD) and low (VSS). VDD = 1.8V, VSS = 200m+ 10mVp-p, 1GHZ. I wrote the following piece of code but it gives me an error saying "contribution statement  encountered inside an analog event"
Assume Td_p,Td_n = 1p
    @(cross(V(Vin)-(V(V_swing)/2),+1)) begin
           V(V_ph) =  V(Vss);
   @(cross(V(Vin)-(V(V_swing)/2),-1)) begin
       V(V_ph)  =  V(Vdd);
       V(Vout) <+ transition(V(V_ph),0,Td_p,Td_n);
But the code works if I change V_ph as a real  variable. But I dont see the 1Ghz 10mVp-p sinusoid on 200m(dc) VSS. Instead it is a constant 200m low and 1.8 V high. Can someone help me with this.
View Profile kumar.g write2rammy   IP Logged
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Re:  Issues in Modelling an INV output having 10mVp-p as its VSS
Reply #1 - Jul 5th, 2010, 4:30am
As the error says, the problem is with the contribution statement inside an event: that's not allowed. Instead, you should assign to a variable inside the event and contribute the variable value outside the event. In your case you can do without the contribution and use the variable value directly in the transition function:
  V_ph_value = V(Vss);
  V_ph_value  =  V(Vdd);
V(Vout) <+ transition(V_ph_value, 0, Td_p, Td_n);
Cheers,
Marq
boe
Reply #2 - Jul 5th, 2010, 11:08am
kumar,
Note that Code:
V(Vout) <+ ...
places a voltage source between node 0 (global simulator ground: 0 V) and node Vout. If you want the source between VSS and Vout, you have to use Code:
V(Vout, VSS) <+ ...
BOE
