Jul 17th, 2024, 10:39am
port probes: VerilogAMS vs VerilogA (Read 3489 times)
Misha
Jul 06th, 2010, 5:03am
I have a VerilogA model that is working well in Spectre/APS.  How I'm trying to simulate the design with Cadence AMS and get an error during the elaboration stage:
Quote:
     B = I(<mp>)/area;
ncelab: *E,SYERROR (...<mypath>/veriloga/verilog.vams,102|10): Port probes are not supported in modules with hierarchy.
This a cell with some RLC components instantiated and in the code I'm trying to sens the current through one terminal.  In the verilogA code this line uses the following syntax:
  B = I(mp,mp) / area;
I tried naming this branch explicitly, but it does not help.
Any idea how I can work around this?
Thanks a lot in advance!
Misha
Re: port probes: VerilogAMS vs VerilogA
Reply #1 - Jul 6th, 2010, 11:18am
You probably have to go in and create an internal node
module yourmod(mp, ...)
inout mp, ...;
electrical mp, ...;
electrical mp_int;
B = I(mp, mp_int) / area;
and then connect all the internal hierarchy to mp_int instead of mp.
Misha
Reply #2 - Jul 8th, 2010, 6:47am
Thank you for the suggestion.  It does work. But the problem turned out to be slightly different.  In a different location of the code I had the same line with an addition originating from the ahdllib code that I used as a base for my model:
Quote:
`ifdef __VAMS_ENABLE__
     B = I(<mp>)/area;
`else
     B = I(mp,mn)/area;
`endif
I guess it's a bug - the AMS simulator takes the first syntax but it actually is compliant with the second, same as the good old Spectre.  I guess the Cadence's ahdllib was never QC'd with AMS simulator.  Watch out for that VAMS_ENABLE macro Smiley.
Thanks anyway for the advice,
Misha
