Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Jul 18
th
, 2024, 11:28am
Home
Help
Search
Login
Register
PM to admin
Simulators
Circuit Simulators
› ppm detector
Previous topic
Next topic
ppm detector (Read 2199 times)
supermoment
ppm detector
Jul 11
th
, 2010, 8:33pm
I got a phase loop for random data running at 5GHz 200ps. Because the BW is only around 4MHz, the ppm detector got to be around 0.2ps resolution or +/-800ppm. (correct me if i am wrong).
the structure is 5GHz clk following by a divider32(156.25MHz or 6.4ns) and then a counter with N bits. The 156.25MHz is used due to the clkref in the freq loop.
To achieve the resolution -->200ps/2048 = 0.1ps (500ppm)
The one cycle of ppm detector will be 6.4ns x 2048=13.1us!!
How could I simulate this in spectre?
Unless i use higher freq clk to the counter.
Is the above statement correct??
IP Logged
Re: ppm detector
Reply #1 -
Jul 14
th
, 2010, 7:05pm
Hi Casual,
I don't understand what your circuitry is going to do. What does ppm mean in your scenario?
By the way, I think your question should be posted in design section, like mixed signal design or high speed communication.
Yawei
IP Logged
supermoment
Re: ppm detector
Reply #2 -
Jul 27
th
, 2010, 12:29am
It is a freq detector that have capability to set ppm (part per million) of a freq. I posted in the analog forum but moderators shifted it to here.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
»» Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
