Jul 17th, 2024, 10:30am
Problems with verilog AMS code from designer's guide website (Read 10644 times)
love_analog
Jul 14th, 2010, 3:19pm
Hi I was trying to compile the PLL code downloaded from
http://www.designers-guide.org/VerilogAMS/
I get compilation errors with the following msg. Can anyone confirm that the code is broken & what needs to be done to fix it.
ncvlog: *E,FNDKWD (./my_rtl/pfd.v,14|34): A SystemVerilog keyword was found where an i
dentifier was expected.
module pfd (qinc, qdec, active, ref, reset);
ncvlog: *E,EXPRCC (./my_rtl/pfd.v,14|42): expecting a right brace ('}') [13.3.1(IEEE)]
   input reset, active, ref;
ncvlog: *E,FNDKWD (./my_rtl/pfd.v,16|27): A SystemVerilog keyword was found where an i
   always @(posedge ref or posedge fr_rst) begin
ncvlog: *E,ILLPRI (./my_rtl/pfd.v,27|23): illegal expression primary [4.2(IEEE)].
ncvlog: *E,CBYREF (./my_rtl/pfd.v,27|23): The 'ref' formal argument direction is only
allowed within tasks and functions.
ncvlog: *E,FNDKWD (./my_rtl/pfd.v,27|26): A Verilog keyword was found where an identif
ier was expected.
ncvlog: *E,EXPSMC (./my_rtl/pfd.v,27|42): expecting a semicolon (';') [12.3.2(IEEE)].
           if (fr_rst) q1 <= 0; else q1 <= 1;
ncvlog: *E,EXPSMC (./my_rtl/pfd.v,28|15): expecting a semicolon (';') [12.3.2(IEEE)].
ncvlog: *E,EXPSMC (./my_rtl/pfd.v,28|21): expecting a semicolon (';') [12.3.2(IEEE)].
loveanalog.blogspot.com
The Power of Analog
Re: Problems with verilog AMS code from designer's guide website
Reply #1 - Jul 14th, 2010, 4:49pm
Apparently 'reset' is a keyword in system-verilog. You should change 'reset' to something else, such as 'rst'.
