Jul 17th, 2024, 10:43am
VerilogA into Device Netlist (Read 1915 times)
e.fisher
Edinburgh
Jul 29th, 2010, 1:49am
Hello.
Quick query. I have an extracted net list of a semiconductor pn junction device, i.e. the net list of the extracted capacitances, bulk resistances etc. The device is DRC and LVS clean but does not include the devices behaviour.
I have a separate VerilogA electrical behavioural model of the device which takes in a generic trigger pulse and gives the correct (verified) behaviour at its anode and cathode.
Of course If I put both into schematic the block will no longer LVS as the VerilogA is essentially not there.
Instead I want to add the VerilogA model into net list, preferably with code to only simulate if in electrical simulation mode rather than LVS or DCR modes.
The VerilogA prototype is:
module GeigerModel(PLUS, MINUS, PULSE)
Thanks very much.
Ed Fisher
Re: VerilogA into Device Netlist
Reply #1 - Jul 29th, 2010, 5:29am
You probably need to tell us what tools you're using.  Some tools generate a different netlist for LVS than for Spice simulation; I think Cadence has some sort of "hierarchy editor" that allows you to substitute behavioral models for various blocks, etc.
