Jul 18th, 2024, 7:23am
Lookup Table - Voltage in/ Voltage Out    - SPECTRE (Read 1257 times)
kevinvinv
Jul 30th, 2010, 4:05pm
What would be the best way for me to implement a voltage in, voltage out lookup table in spectre?
__________________
Kevin
Re: Lookup Table - Voltage in/ Voltage Out    - SPECTRE
Reply #1 - Jul 30th, 2010, 7:30pm
Kevininv,
  Use the Verilog-A table model.
kevinvinv
Reply #2 - Jul 31st, 2010, 11:36am
I was hoping for something other than Verilog A...   Simulating without verilog-A is like living life without a stomach ache.  Almost every time I have convergence issues- I trace it to a verilogA block.  Anyhow-  if that is my only option-  I guess I'll give it a go.
Thanks!
__________________
Kevin
Reply #3 - Aug 3rd, 2010, 5:16am
trace it to a ... poorly-written? ... verilogA block?
There are lots of examples of poorly-written Verilog-A modules here.  You do sort of need a basic understanding of the mechanics of Spice -- Newton-Raphson, so the module had better have continuous derivatives, etc.
Be careful when you build your $table_model -- some splines can give strange values when extrapolating, or even when interpolating, such that the Newton solver will get confused.
kevinvinv
Reply #4 - Aug 3rd, 2010, 5:33am
You know I've heard that "You just need to write it correctly" sort of thing.  I've written a lot of VerilogA.  I've used examples from the Cadence ahdl Lib unmodified,  I've read books and taken classes.  Bottom line-  it more often than not is the cause of my convergence problems.   I have MUCH better luck using analogLib components to model behavior.
I suppose I am still doing something wrong   Smiley
Thanks for the comments!  I appreciate it!
I got my table model working- did indeed see strange interpolation but when I switched to order "1" -  I got what I wanted-  just standard PWL.
Thanks again!
__________________
Kevin
Reply #5 - Aug 3rd, 2010, 11:04am
Kevin,
    There are a series of very common mistakes that people make with Verilog-A that tend to cause most of the problems. Once you understand the language well enough not to make those, life with Verilog-A gets much easier. Next time Verilog-A causes you grief, consider posting your model to this forum. Perhaps we can point out your mistake.
