Sep 29th, 2026, 6:49am
Command Execution Sequence in VerilogA (Read 5380 times)
neoflash
Mixed-Signal
Designer
Aug 02nd, 2010, 4:04pm
I observed one interesting phenomenon:
When variables used in one cross() function are assigned value outside of this cross() function, the sequence of execution is not predictable.
Below is the code I used for simulation, up0 is expected to be updated before used for calculation of up_int, however, it is not. Up_int still calculates based on old up0 value, although up0 seems to be updated immediately with new e0 value.
As a comparison, e0_int is using the new e0 value all the time.
This is really unpredictable whether veriloga's cross function is based on blocking or non-blocking assignment.
Any comments?
@(cross(V(ck_i)-0.5,+1,1e-12)) begin
     e0= (V(rxp) > V(rxn)) ? 1 : 0;
     e0_int = e0;
     up_int=up0+up1;  // up_int is using old up0 value.
up0= (d0 + e0) %2;
Re: Command Execution Sequence in VerilogA
Reply #1 - Aug 2nd, 2010, 7:40pm
The statements are executed in order. The concept of blocking is not used in an analog block. Instead, the statements contained within an @ block are simply skipped except at the instant at which the event occurs.
Ari
Israel
Reply #2 - Sep 30th, 2010, 10:42am
Ken,
I face the same problem with unpredictable order of execution.
I contacted the CAD vendor, yet I could not find any specification in Verilog-AMS LRM 2.3.1 for order of execution in such cases.
Can you please specify where this order of execution is stated in the LRM ?
Ari
Reply #3 - Sep 30th, 2010, 2:16pm
Section 5.2 of the LRM says that "All statements within the analog block shall be executed sequentially at a given point in time".
