newic wrote on Aug 6th, 2010, 11:30pm:how do I make the default save option from "allpub" to "selected" in the Cadence cdsinit file??
What simulator engine do you use ?
I assume you use Cadence Spectre.
Add following in ".cdsinit".
Code:envSetVal("spectre.outputs" "save" 'string "selected")
The followings are general notes for you.
- Always describe correct tool's name and vendor's name which you use as tool or simulator.- Don't do multiple posts which are same content.
- Don't request source code or behavioral model without any efforts.
- There are many simulators which have analyses called as PSS, PAC and Pnoise.
- Describe in detail with using correct terminologies.
- Warnigns are different from Errors.
- ADS is not name of simulator.
- There is no tool which name is Cadence.
- Don't use Direct Plot of Cadence ADE blindly without knowing definition.
- All gains in Direct Plot of Cadence ADE are "right", "true" and "practical" voltage gain.
- Don't mix up Simulation with Post Processing. They are completely different phase.
- MATLAB are different from Simulink.
- Learn measurements using actual instruments. Not "EDA Tool Play
