Jul 18th, 2024, 1:15am
How to run system commands like copy or move in ocean script? (Read 1475 times)
pkd
India
Aug 12th, 2010, 6:24pm
I want to know how to run system commands like copy or move in ocean script. I see some system commands "ls" working in ocean too. But "mv" or "cp" don't work out. Is it possible to pass the normal system commands in ocean script itself?
Eg. in perl scripting language we use the system() command to do similar job. Does similar feature exist in ocean scripting language?
-pd
Re: How to run system commands like copy or move in ocean script?
Reply #1 - Aug 13th, 2010, 3:22am
pkd wrote on Aug 12th, 2010, 6:24pm:
It can not be such that.
Do you set aliases for "mv" and "cp" ?
Show me the results of the followings in Unix command line.
which mv
which cp
Try the followings.
system( "touch /tmp/aho" )
system( "\cp /tmp/aho /tmp/boke" )
