Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Jul 18
th
, 2024, 1:32am
Home
Help
Search
Login
Register
PM to admin
Simulators
Circuit Simulators
› Monte Carlo/ MMSIM7/ IBM 8hp
Previous topic
Next topic
Monte Carlo/ MMSIM7/ IBM 8hp (Read 1920 times)
Lu
Aug 13
th
, 2010, 1:21pm
I am doing Monte Carlo simulation (Process) using Spectre 7.1 in IBM 8hp 130nm, but the results showed broad variation. How can I find out which of the process parameters are responsible for this or how can I run Monte Carlo simulation by only varying one of the process parameters.
IP Logged
Re: Monte Carlo/ MMSIM7/ IBM 8hp
Reply #1 -
Aug 16
th
, 2010, 5:56am
Do you have access to the model library (in an unencrypted format)? If so, you might be able to go in and modify the statistical distributions.
Have you looked through the output of "spectre -help montecarlo" ?
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
»» Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
