Jul 17th, 2024, 10:22am
ODE solving in verilog-A? (Read 765 times)
manus
Aug 26th, 2010, 3:44pm
If a differential equation is being solved in verilog-a, how are the initial conditions set? There doesn't seem to be any requirement that initial conditions be provided. What does it do without initial conditions? What's the way to force initial conditions?
I'm using verilog-a to model an electro-mechanical system with a 2nd order ODE governing the kinematics.
Pos(x):ddt(Vel(vl))==-gamma*Vel(vl)/Mro-Kro/Mro*Pos(x)+F(Fw)/Mro;
F(Fw) has been assigned as a function of input voltages in a preceding line.
Thanks!
carlgrace
Berkeley, CA
Re: ODE solving in verilog-A?
Reply #1 - Aug 26th, 2010, 4:27pm
Have you tried forcing the various parameters during the @(initial_step) code block?
Carl
manus
Reply #2 - Aug 26th, 2010, 4:42pm
Is the @(initial_step) code block used for all analyses, or just transient?
I can set an initial condition for Vel(vl) that way, but I can't set an initial condition for Pos(x). If I try to set an initial condition for Pos(x) I get the error: "Encountered an illegal mixing of direct and indirect assignments to branch quantity 'x'. Remove one of the assignments and try again."
For a second order ODE I think I need to set two initial conditions to solve for all parameters. Is there another way to set an initial condition for Pos(x) that verilog-a will allow?
