manus
Is the @(initial_step) code block used for all analyses, or just transient?
I can set an initial condition for Vel(vl) that way, but I can't set an initial condition for Pos(x). If I try to set an initial condition for Pos(x) I get the error: "Encountered an illegal mixing of direct and indirect assignments to branch quantity 'x'. Remove one of the assignments and try again."
For a second order ODE I think I need to set two initial conditions to solve for all parameters. Is there another way to set an initial condition for Pos(x) that verilog-a will allow?
