Is it possible you have multiple dc operating points?
You could try taking the "wrong" solution from +turbo and giving that to plain spectre and seeing if it converges. If so, there are multiple operating points, and you need some sort of nodeset to push +turbo to find the right one. Hopefully, you can find a few nodes to set, rather than resorting to using plain spectre just for the dc op pt.
