Jul 16th, 2024, 7:47am
Nonlinear Dependent Sources in HSpice (Read 707 times)
bhavuli
Sep 07th, 2010, 12:44pm
Dear all.
I am trying to simulate a very simple circuit in Synopsys HSpice which should have a current-dependent current source (CCCS).
However, this CCCS must be a nonlinear.
While I am be to find in the user manual the support for polynomial, delay, ... type of CCCS, I am not able to find how to include other arithmetic functions.
For example, my CCCS should take the log() of the current it is dependent on. That is:
Vbias p 0 10
R1 p 0 50
** and then
CCCS that should take the log() or other function of the current through R1
Please, please help me on this; I have tried for a couple of day, but have not progressed. Please help me on this.
Thank toy for your time and help.
Best regards,
Re: Nonlinear Dependent Sources in HSpice
Reply #1 - Sep 8th, 2010, 8:58am
bhavuli wrote on Sep 7th, 2010, 12:44pm:
Surely read documents of HSPICE.
The followings are extractions from documents of HSPICE. Quote:
Current-Dependent Current Sources — F-elements
This section explains the F-element syntax and parameters.
Note:
G-elements with algebraics make F-elements obsolete. You can still use Felements for backward-compatibility with existing designs.
Use G-Element instead of F-Element.
Gxxx n+ n- CUR=’equation’ <MAX>=val> <MIN=val> <M=val> <SCALE=val>
bhavuli
Reply #2 - Sep 9th, 2010, 10:53am
Thank you very much for this pancho_hideboo!
