Shahriar
Chelsmford, MA
I've used these two setups.
1) The pfd with both vco and ref from two vpulse - one with 32kHz, the other with 32.001kHz, both starting at 0. The first positive edge of vco leads that of ref by 488.3ps. This difference shows up in the graph and pfd gives a down pulse. Every time difference in according edges thus shows up in the graph. Output log is below:
Important parameter values: start = 0 s outputstart = 0 s stop = 200 us step = 200 ns maxstep = 2 us ic = all skipdc = no reltol = 10e-06 abstol(I) = 1 pA abstol(V) = 1 uV temp = 27 C tnom = 27 C tempeffects = all errpreset = conservative method = gear2only lteratio = 10 relref = alllocal cmin = 0 F gmin = 10e-51 S maxrsd = 0 Ohm mos_method = s mos_vres = 50 mV
tran: time = 5.761 us (2.88 %), step = 765.2 ns (383 m%) tran: time = 15.62 us (7.81 %), step = 930.2 ns (465 m%) tran: time = 25.56 us (12.8 %), step = 753.7 ns (377 m%) tran: time = 36.14 us (18.1 %), step = 1.907 us (953 m%) tran: time = 45.51 us (22.8 %), step = 1.365 us (682 m%) tran: time = 55.39 us (27.7 %), step = 683.2 ns (342 m%) tran: time = 65.66 us (32.8 %), step = 991.6 ns (496 m%) tran: time = 75.68 us (37.8 %), step = 2 us (1 %) tran: time = 85.14 us (42.6 %), step = 509.8 ns (255 m%) tran: time = 95.03 us (47.5 %), step = 210 ns (105 m%) tran: time = 106.1 us (53.1 %), step = 1.764 us (882 m%) tran: time = 115.3 us (57.7 %), step = 416.3 ns (208 m%) tran: time = 125 us (62.5 %), step = 338.3 ps (169 u%) tran: time = 135.6 us (67.8 %), step = 1.414 us (707 m%) tran: time = 145.2 us (72.6 %), step = 338.2 ns (169 m%) tran: time = 155.6 us (77.8 %), step = 660.2 ns (330 m%) tran: time = 165.8 us (82.9 %), step = 1.201 us (601 m%) tran: time = 175.1 us (87.5 %), step = 249.3 ns (125 m%) tran: time = 185.4 us (92.7 %), step = 553.7 ns (277 m%) tran: time = 195.3 us (97.6 %), step = 1 us (500 m%)
2) This time the ref is vpulse with 32kHz and the veriloga block for vco set with 493.16mV control voltage to give 32.001kHz. I've checked the value of f with $strobe. But, in this case, if bound_step is set to 1000, time step is always 31.25ns. In this case, the first 23 pulses of vco and vref are perfectly aligned and the 24th pulses show up with vco leading ref by 22.47ns and pfd gives the first down down pulse here. The output log is below:
Important parameter values: start = 0 s outputstart = 0 s stop = 1 ms step = 1 us maxstep = 10 us ic = all skipdc = no reltol = 10e-06 abstol(I) = 1 pA abstol(V) = 1 uV temp = 27 C tnom = 27 C tempeffects = all errpreset = conservative method = gear2only lteratio = 10 relref = alllocal cmin = 0 F gmin = 10e-51 S maxrsd = 0 Ohm mos_method = s mos_vres = 50 mV
tran: time = 25.02 us (2.5 %), step = 31.25 ns (3.12 m%) tran: time = 75.02 us (7.5 %), step = 31.25 ns (3.12 m%) tran: time = 125 us (12.5 %), step = 22.39 ns (2.24 m%) tran: time = 175 us (17.5 %), step = 31.25 ns (3.12 m%) tran: time = 225 us (22.5 %), step = 31.25 ns (3.12 m%) tran: time = 275 us (27.5 %), step = 31.25 ns (3.12 m%) tran: time = 325 us (32.5 %), step = 31.25 ns (3.12 m%) tran: time = 375 us (37.5 %), step = 22.39 ns (2.24 m%) tran: time = 425 us (42.5 %), step = 31.25 ns (3.12 m%) tran: time = 475 us (47.5 %), step = 31.25 ns (3.12 m%) tran: time = 525 us (52.5 %), step = 31.25 ns (3.12 m%) tran: time = 575 us (57.5 %), step = 31.25 ns (3.12 m%) tran: time = 625 us (62.5 %), step = 22.39 ns (2.24 m%) tran: time = 675 us (67.5 %), step = 31.25 ns (3.12 m%) tran: time = 725 us (72.5 %), step = 31.25 ns (3.12 m%) tran: time = 775 us (77.5 %), step = 31.25 ns (3.12 m%) tran: time = 825 us (82.5 %), step = 31.25 ns (3.12 m%) tran: time = 875 us (87.5 %), step = 1.559 ns (156 u%) tran: time = 925 us (92.5 %), step = 31.25 ns (3.12 m%) tran: time = 975 us (97.5 %), step = 31.25 ns (3.12 m%)
The only default value in the options I've changed is gmin, otherwise the control voltage was very slowly dropping.
If I use bound_step as big as 100000 (step becomes 312.5ps), only then I get accurate results. I guess I'm missing something about bound_step. I understand that it controls maxstep in simulation. But why is step always equal to bound_step?
Should I decrease rel_tol? I've tried with 1e-12, didn't work.
I also used the time_tol parameter in "transition", didn't work.
