Jul 17th, 2024, 10:32am
how to flush out the buffer in verilog A? (Read 4282 times)
Irvin73
Israel
Sep 27th, 2010, 10:19am
I run relatively long transient spectre simulation with some verilog-A block which on each "cycle" of simulation should print data to the log file. Like in following example -
@(cross(V(CNT_RST)-vth, +1)) begin
           // ... some code here
	   $fwrite(logFile,"%d\t%.2f\t%.2f\t%.2f\n", row_index, cds_code,reset_code,signal_code)
The problem is that the log file updated only after the simulation completes, and I want to do monitoring of the log during the simulation. I think there is some way to control the flushing of the buffer, can anyone help with this?
Tnanks.
Re: how to flush out the buffer in verilog A?
Reply #1 - Sep 28th, 2010, 6:04am
Try
$fflush(logFile);
Irvin73
Israel
Reply #2 - Sep 28th, 2010, 6:36am
It works, many thanks!
Interesting thing - this function is not documented, at least I can't find it in "Cadence®Verilog®-A Language Reference" pdf (2006). Is my documentation obsolete? Smiley
Thanks again for quick and useful response.
Reply #3 - Sep 29th, 2010, 8:45am
I found this in the IEEE 1800-2009 standard.
I know some vendors implement features like this in their (digital) Verilog simulators, and then I guess it's an easy port to add to their analog or AMS simulators.
