Jul 17th, 2024, 10:32am
Printing loop variable (Read 2513 times)
Peter_R_Kroon
The Netherlands
Oct 04th, 2010, 2:23am
I want to print, via the display function, the value of an integer loop variable. If I use %d (decimal) I get a large number of spaces in front of the printed loop variable. Using %s (string) or %c (character) is not the solution because I must print an integer value.
How can I avoid or suppress the large number of spaces in front of the printed loop variable?
Re: Printing loop variable
Reply #1 - Oct 4th, 2010, 2:16pm
I don't believe the V-AMS LRM says anything about putting spaces in front of a number; I expect it to follow the C convention for format specifiers.  Have you asked your simulator vendor?
Reply #2 - Oct 4th, 2010, 3:14pm
Try using %0d. That indicates that the minimum field width is what is desired.
Peter_R_Kroon
The Netherlands
Reply #3 - Oct 5th, 2010, 4:53am
Ken,
Thanks for your suggestion, it indeed solves the problem.
Peter
