Jul 17th, 2024, 11:35pm
hspice in ADE (Read 1648 times)
sivacha
India
hspice in ADE
Oct 11th, 2010, 3:06am
Hi
When i tried to run hspice on any schematic through ADE, i am getting some error like " Enter the name of the output file: (input.lis) " in the log window. But i can not edit log file.
Where can I enter the output file name?
Can any body suggest a solution???
Thanks.
Re: hspice in ADE
Reply #1 - Oct 11th, 2010, 10:22am
Probably your ADE isn't configured properly.  I think there's a command-line argument that tells HSpice to use input.lis without prompting (assuming the netlist was input.sp).
