Jul 18th, 2024, 11:23am
nomod in hspice (Read 2302 times)
ontheverge
nomod in hspice
Oct 12th, 2010, 2:02pm
the library file I'm using is long (includes corners and binning) so I tried not to display it in hspice simulation result by using
.options post nomod
however, 'nomod' doesn't seem to work, anything wrong here?
thanks,
Steve
Re: nomod in hspice
Reply #1 - Nov 1st, 2010, 6:49pm
Hi Steve,
.options nomod is used to suppress model parameters printing. That means the simulator does not print the model parameters of each instances. If you do not want to print the library file in output log, please use .prot as below.
.PROT $protect statements below .PROT
.LIB 'MOS.LIB' FAST $get fast model library
.UNPROT
Yawei
ontheverge
Re: nomod in hspice
Reply #2 - Nov 7th, 2010, 12:05am
Thank you, Yawei!
