Hi Steve,
.options nomod is used to suppress model parameters printing. That means the simulator does not print the model parameters of each instances. If you do not want to print the library file in output log, please use .prot as below.
.PROT $protect statements below .PROT .LIB 'MOS.LIB' FAST $get fast model library .UNPROT
Best Regards, Yawei
