Prashant Babu
I tried the following code:
`define BITS_IN_REG 288
module SIPOREG_288BIT(vin_d, vout_d, vclk);
output [`BITS_IN_REG-1:0] vout_d;
electrical vin_d; electrical [`BITS_IN_REG-1:0] vout_d; electrical vclk;
parameter real vlogic_high = 5; parameter real vlogic_low = 0; parameter real vtrans = 2.5; parameter real tdel = 3u from [0:inf); parameter real trise = 1u from (0:inf); parameter real tfall = 1u from (0:inf);
integer d[0:`BITS_IN_REG-1];
integer bit_num;
analog begin
// // roll the register and load the new input bit // @ (cross( V(vclk) - vtrans, +1, 1.0, vclk.potential.abstol) ) begin for (bit_num = (`BITS_IN_REG-1); bit_num > 0; bit_num = bit_num-1) d[bit_num] = d[bit_num-1]; d[0] = V(vin_d) > vtrans;
generate i (0,(`BITS_IN_REG-1)) begin V(vout_d[i]) <+ transition((d[i] ? vlogic_high : vlogic_low), tdel,trise,tfall); end
`undef BITS_IN_REG
However, the problem is that the outputs are generated only after all the data have been shifted.
How can I shift as well as generate the output at the same time? For example, I want the output vout_d[0:277] at each bit shift. I cant use the "generate" statement within the @cross because it gives me an error. Anybody out there who can help me out with this?
