Jul 17th, 2024, 12:44pm
288 bit SIPO register (Read 1994 times)
Prashant Babu
Oct 20th, 2010, 2:21am
Can anybody please tell me how to write a Verilog-A code for a 288 bit SIPO register.
Since the number of bits are quite large, I tried to use "for" loop statements for assigning values and also in the transition statement, but have been getting a lot of errors.
Any help will be appreciated.
Prashant
Prashant Babu
Re: 288 bit SIPO register
Reply #1 - Oct 20th, 2010, 6:40am
I tried the following code:
`define BITS_IN_REG 288
module SIPOREG_288BIT(vin_d, vout_d, vclk);
output [`BITS_IN_REG-1:0] vout_d;
electrical vin_d;
electrical [`BITS_IN_REG-1:0] vout_d;
electrical vclk;
parameter real vlogic_high = 5;
parameter real vlogic_low = 0;
parameter real vtrans = 2.5;
parameter real tdel = 3u from [0:inf);
parameter real trise = 1u from (0:inf);
parameter real tfall = 1u from (0:inf);
 integer d[0:`BITS_IN_REG-1];
 integer bit_num;
 analog begin
    // roll the register and load the new input bit
    @ (cross( V(vclk) - vtrans, +1, 1.0, vclk.potential.abstol) ) begin
       for (bit_num = (`BITS_IN_REG-1); bit_num > 0; bit_num = bit_num-1)
           d[bit_num] = d[bit_num-1];
       d[0] = V(vin_d) > vtrans;
     generate i (0,(`BITS_IN_REG-1)) begin
         V(vout_d[i]) <+ transition((d[i] ? vlogic_high : vlogic_low), tdel,trise,tfall);
`undef BITS_IN_REG
However, the problem is that the outputs are generated only after all the data have been shifted.
How can I shift as well as generate the output at the same time?
For example, I want the output vout_d[0:277] at each bit shift.
I cant use the "generate" statement within the @cross because it gives me an error.
Anybody out there who can help me out with this?
