Jul 17th, 2024, 12:36pm
idt() function in hspice simulator (Read 1291 times)
neoflash
Mixed-Signal
Designer
Oct 23rd, 2010, 11:37pm
I used idt() function in hspice simulator for a VCO.
However, I got trouble that sometimes the idt() output result may jump erroneously.
Is there any option that I can help with this issue?
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Re: idt() function in hspice simulator
Reply #1 - Nov 17th, 2010, 6:36am
You will need to provide a little more information if you want us to help you.
Anyway, when you mentino VCO I would suggest you have a look at the idtmod() operator instead of the idt() operator.
Cheers,
Marq
neoflash
Mixed-Signal
Designer
Reply #2 - Nov 17th, 2010, 11:58am
Marq Kole wrote on Nov 17th, 2010, 6:36am:
Cheers,
Marq
idtmod() works much better and solves the problem. Thanks.
neoflash
Mixed-Signal
Designer
Reply #3 - Nov 20th, 2010, 3:28pm
finesim doesn't support this special idtmod() function. sucks.
Marq Kole
Hmmm. That's
weird...
Reply #4 - Dec 8th, 2010, 8:12am
That's weird - I'm using finesim 2010.08.00 and the code below runs just fine:
`include "disciplines.vams"
`include "constants.vams"
module va_vco2 (out, ctrl, ref);
  parameter real amp = 1;
  parameter real minfreq = 1M;
  parameter real gain = 1.2M;
  inout ctrl, out, ref;
  voltage ctrl, out, ref;
  real phase, freq;
  analog begin
    freq = minfreq + gain * V(ctrl, ref);
    phase = `M_TWO_PI * idtmod(freq, 0, 1);
    $bound_step(0.1 / freq);
    V(out, ref) <+ 0.5 * amp * (cos(phase) + 1);
Are you using a recent version? We have no trouble with the Verilog-A support of finesim.
Cheers,
Marq
neoflash
Mixed-Signal
Designer
Reply #5 - Dec 8th, 2010, 12:11pm
We are using the most recent version.
