Jul 18th, 2024, 9:13am
convert spectre model file to hspice file (Read 2175 times)
ontheverge
Nov 07th, 2010, 1:07am
I don't have hspice simulator on cadence, but have access to Avant Hspice simulator.  I'm wondering if it's possible to convert spectre model file (.scs) to hspice compatible model file and how?
thanks,
Steve
Re: convert spectre model file to hspice file
Reply #1 - Nov 8th, 2010, 6:07am
It's usually possible, though it could be a lot of work, depending on how complicated the model file is.
First thing to check is that all the models referenced are standard models (eg, bsim3v3) -- if you have a Cadence-proprietary models, then you're out of luck.
(I hope you have a recent HSpice -- Avant! was bought out years ago.)
If the library is complicated -- and you care about the complications -- then I'd recommend asking your foundry for HSpice models.  Things like corner models and statistics could be a nuisance to translate.
