Aug 16th, 2024, 4:34pm
How to trace analog value as real value ? (Read 2092 times)
sand_dolphin2
Japan
Nov 09th, 2010, 12:53am
Hi guys,
Now, I want trace hierarchical analog value as real value.
Hierarchical Nod name is
 TESTBENCH.DUT.SUB_A.SUB_A_B.node_abc
and the SUB_A_B block is made by schematic.
I define real value as bellow in verilog ams module.
real real_value_node_abc;
real_value_node_abc = TESTBENCH.DUT.SUB_A.SUB_A_B.node_abc;
but compile error occur on AMS Designer of Cadence.
here is irun.err
ncvlog: *E,EXPLPA (aaa.vams,29|11): expecting a left parenthesis ('(') [12.1.2][7.1(IEEE)].
ncvlog: *E,ILLHIN (aaa.vams,29|44): illegal location for a hierarchical name (TESTBENCH).
ncvlog: *E,EXPLPA (aaa.vams,29|52): expecting a left parenthesis ('(') [12.1.2][7.1(IEEE)].
       module worklib.aaa:vams
               errors: 3, warnings: 0
please let me know how to refer analog value as real.
Undecided
btw:
Sorry for confusing you in always my bad English.
Re: How to trace analog value as real value ?
Reply #1 - Nov 9th, 2010, 5:29am
If the node were local to the module and declared as discipline electrical, you'd do:
real_value_node_abc = V(node_abc);
because V() is the access function for electrical.
I'm not sure how this will work with the hierarchical node name, nor what discipline is assumed for that node.
sand_dolphin2
Japan
Reply #2 - Nov 9th, 2010, 3:17pm
Geoffrey_Coram wrote on Nov 9th, 2010, 5:29am:
@Geoffrey_Coram
thx for your good advice,
now i correct verilog ams code as your advice.
But after correcting , still now Error occur ( error number were reduced from 3 to 1 )
i want to check analog value of nodes of schematics base design.
here is irun.err
file: aaa.vams
real_value_node_abc = V(TESTBENCH.DUT.SUB_A.SUB_A_B.node_abc);
ncvlog: *E,EXPLPA (aaa.vams,30|20): expecting a left parenthesis ('(') [12.1.2][7.1(IEEE)].
               errors: 1, warnings: 0
even though bellow code, same error occur
electrical tempa = TESTBENCH.DUT.SUB_A.SUB_A_B.node_abc;
real_value_node_abc = V(tempa);
and proving to node which is made by verilog ams has same error too...
What does this error message means ?
i'm not sure this error comes from hierarchical node name...
plz give me some advice...
i'm waiting for your kind.
Smiley
Reply #3 - Nov 9th, 2010, 5:58pm
You've cut out too much. The error is in the code above the line you are showing.
sand_dolphin2
Japan
Reply #4 - Nov 10th, 2010, 11:36pm
i should correct,
here is Verilog Ams code which occur error
and here is irun.error
when i comment out verilog ams code like this, do not occur this error.
//real_value_node_abc = V(TESTBENCH.DUT.SUB_A.SUB_A_B.node_abc);
i wonder
1)Mr Geoffrey_Coram's comments
2)one phrase of irun Error message
plz give me some kind....
Reply #5 - Nov 11th, 2010, 12:35am
I think you need to put that code inside an analog block.
You make it difficult to help you by only giving us a line or two at a time. It would be better to cut your example down as small as can be such that it still exhibits the problem and then give the whole example. It is sometimes hard to find problem if you can't examine the whole model.
sand_dolphin2
Japan
Reply #6 - Nov 11th, 2010, 12:56am
Dear kundert,
Ken Kundert wrote on Nov 11th, 2010, 12:35am:
OK, I fully agree w/t u.
I'll try to make sample code to make same error.
DUT and TEST bench
plz wait for moment.....
Smiley
sand_dolphin2
Japan
Reply #7 - Nov 11th, 2010, 5:54pm
word, i solved this problem!
and this function work well..
any thx ...
correct verilog ams code is here
analog begin
next , i will add sample.
Wink
haykp
Reply #8 - Nov 11th, 2010, 10:32pm
Hi Sand_dolphin2,
Please sorry for my out of context question, but I need your answer very much.
So from your question I see that you are working with analog verilog or verilog ams. I am not very familiar with analog verilog, but I know pretty well the verilog digital one.
So it is not clear for me why to use analog verilog, if we have spice or other analog simulators. Could you please expand why you use the analog verilog, why spice is not acceptable for your issue. My belief is that using mixed simulations you can always model the analog part with spice and digital part with verilog.
sand_dolphin2
Japan
Reply #9 - Nov 12th, 2010, 12:02am
NVM, and well come your question!!
Because i'm digital engineer of verification and design.
Then i'm so familiar w/t verilog-D than verilog-A same on u,
 we should go to verilog-AMS for Mixed signal simulation u know.
My design include some analog parts which build by schema.
I wana make test bench by verilog-AMS(text base)
and check analog signals by system verilog vir conversion to Digital.
as u know, real and wreal is good for this way.
any other ?
