Jul 17th, 2024, 10:39am
ius820+Unable to load SST2 communication library (Read 3918 times)
mustangyhz
china
Nov 14th, 2010, 12:26am
Unable to load SST2 communication library: /usr/ius/tools/lib/libdcapi.so: cannot open shared object file: No such file or directory or file is not valid ELFCLASS32 library
what dose this mean? how to solve this?
thanks!
mustangyhz
View Profile mustangyhz 3241568   IP Logged
Re: ius820+Unable to load SST2 communication library
Reply #1 - Nov 15th, 2010, 6:27am
Is the file at that location?  My guess is no, that you have an installation problem because I expect to see "cadence" or "cds" in the start of the path, instead of just /usr.  What's the path to the program/binary you are running?  Can you find libdcapi.so in the same directory tree?  (If you are running /usr/applications/cadence/something/version/linux/bin/myexe, then look in /usr/applications/cadence/something/version/linux/lib/)
mustangyhz
china
Reply #2 - Nov 15th, 2010, 5:20pm
thank geoffrey_coram for you reply.
for me:
cadence install path:      /usr/cadence
ius8.2 install path:      /usr/ius
I found the file "/usr/ius/tools/lib/libdcapi.so" with a arrow.  what is libdcapi.so?
[root@mml 64bit]# cd /usr/ius/tools/lib
[root@mml lib]# find . -name libdcapi.so
./64bit/libdcapi.so
./libdcapi.so
/usr/pdk/listing01/cda.lib
# cds.lib
INCLUDE /usr/ius/tools/inca/files/cds.lib
DEFINE  worklib /usr/pdk/listing01/work
can I make friends with you?
MSN: minglin_ma@hotmail.com
mustangyhz
