Jul 17th, 2024, 12:47pm
what is amsAPT file (Read 85 times)
idriss
what is amsAPT file
Nov 24th, 2010, 2:43am
Hi Guys
does someone knows what is amsAPT file,what it is and what it does, thank you very much for your help
Idris
Re: what is amsAPT file
Reply #1 - Jan 3rd, 2011, 12:50am
It's a  hangover from old versions of AMS Designer. In the past, the elaborator needed to know what analog primitives were available, so that it knew that these would be supplied later on by the simulator (e.g. any transistor level models) - to do this you had to create an "Analog Primitive Table" (APT) file - there was a tool to do this from spectre models.
However, this has not been needed for many releases now.
